Changing focus to BricsCAD v14 using VBA
I have a VBA app in Excel that draws some objects in BricsCAD. Then, I want to give focus to BricsCAD, so the user can continue to work. I have tried the following without success,
acadApp.Visible = True
Note that earlier in the program the acadApp variable is set to be the BricsCAD app. But, the .visible setting does not seem to have any effect. If I type, the Excel app is what gets the letters.
I see that in v14 of AutoCAD, the method, Window.Focus was added.
The word "Focus" is not in the BricsCAD developer help document. After some internet searches, I found a page that indicates you must load the reference called, "AutoCAD Focus Control for VBA Type Library"
Is there a similar library for BricsCAD?
-Joe
  • Roy Klein Gebbinck
    edited February 2017
    Try using the VBA AppActivate statement.
  • I have tried the following without success.
    AppActivate.acadApp ' doesn't work. Says argument is not optional.
    AppActivate Shell("C:\Program Files (x86)\Bricsys\BricsCAD V14 en_US\bricscad.exe", 1) 'Above doesn't work. Says invalid procedure or call
    -Joe
    Your first suggestion obviously won't work. Why the second fails I do not know.
    Try this SendKey example.
    If you can't get that to work you should consult your IT department. Your system's security may be too tight.
  • After a bunch of trial-and-error, I ended up with this method working.
    AppActivate "BricsCAD"
    Thank you all for your suggestions, working or not.
    -Joe
