Support for high-resolution screens
From the release note
https://bricsys.com/common/news.jsp?item=1606
bricscad v17 should support HiDPI screen.
I've tested it on linux today and the interface doesn't scale to dpi, icons are very tiny.
Is there anything that I can try to be able to support high-resolution screen?
  • If your concern is icon size, please note that you can choose between 3 icon size values 16,32,64 (see setting dialog TOOLBARICONSIZE)
    To modify the icon size, right-click in anywhere outside the the graphic window and in the context menu select 'Toolbar size' and then select 'Small icons', 'Large icons' or 'Extra-large icons'.
