Filtering Extended Entity Data
Hi there,
In the following example I can filter a list of extended entity data based on the app (ssget "X" '((0 . "INSERT") (-3 ("MYAPP"))))
As an example I would like to find a list of entities that have the DXF code 1005 with a value of "571" attached.
Is there a way to refine the filter further without having to create a selection set and then stepping through each entity in the list?
I hope my explanation is clear enough
. Thanks in advance for your help.
Phillip
Not possible in AutoCAD, but BricsCAD does have this feature:
(ssget "_X" '((0 . "INSERT") (-3 ("MYAPP" (1005 . "571")))))0 -
Sweet! That's why I love BricsCAD
Thank you Roy for the timely response.
