Printing problems
in 2D Drafting
Hi there!
I am using Bricscad V17 profesional. I have problems when printing from layout.
some lines that are existing in drawing and I can see them in print preview disapear in drawing when I print it.
If I take the same drawing and try to print it from autocad everything is ok and all lines are there.
Please file a support request and attach a drawing you are having the problem with.
I have had many issues with printing, whether to hard copy or PDF, since V15. Lines and renderings grainy and intermittent. Vertical lines of different width than horizontal lines. Renderings of sheet metal or other 3D objects appearing coal black on the white printing field.
