How to put the dimension line at a certain distance from the objects?
Hi, guys! I would ask you how to put the dimension line (or any other line, circle, etc) at a certain distance from the objects?
I'd use Entity Snap Tracking. Hover to pick up a temporary snap point and then pull out at one of your snap tracking angles to the desired distance.
