Right mouse button
I have changed to V17 from V16 and my previous setting for 'shortcutmenu' was 2 (i.e. Enable Edit mode shortcut menus) therefore when I selected an entity the mouse button right click would give me the edit menu.
With V17 and the same setting applied I get a repeat command.
Any suggestions or have I discovered a problem?
  • In SETTINGS check that SHORTCUTMENU bit 16 isn't checked. This displays the shortcut menu after a long right click only. If this is set short click will default to Enter.
    CAD Concepts
  • Thanks for the reply Jason. All the settings are as per my V16 setup and it is not the same so I have sent an SR to Bricscad for a solution.
  • I might be too late to respond but I just wanted to say that you can customize all the right-click menus to your liking.
