Slice command
Why I use the _slice command from the quadcursor bricscad v17.2.04(x64) open the "block definition" window?
I cannot reproduce the problem. Can you file a support request and add a drawing you are having the problem with?
https://youtu.be/O7HpK-v8SEw this is the problem, with a new draw
I re-post the video
After watching the video I can reproduce the problem. It occurs only when the Select Faces option of the SelectionModes variable is not set.
To correctly execute the Slice command do the followng:- make sure the Select Faces option of the SelectionModes system variable is set.
- press and hold the Ctrl-key when hovering over the solid you want to slice, then click the select the solid.
- select the slice command in the Quad.
- identify the cutting face.
I will inform our developers. Thank you for reporting.
Thank you very much!
I can remove the ugly videos from youtube.0 -
@Louis Verdonck said:
After watching the video I can reproduce the problem. It occurs only when the Select Faces option of the SelectionModes variable is not set.I see the same block creation dialog,
with correct selection mode settings,
when I just select the first object but then press Cancel in the prompt menu.0
