Is there an equivalent comand to REMOVE OBJECTS FROM GROUP in Autocad ?
The GroupEdit command is not available. But you can remove entities via the _Group or _-Group command. If you prefer selecting groups in the drawing area you may like BKG_Group (freeware).
Thank you very much Roy the answer solves my question applied to CADWIORX P&ID on Bricscad
