REGEN consuming RAM
Why REGEN is RAM consuming? … and never will release it! Not so in AC.
If you repeat REGEN many times, you can follow this RAM-stepping in the TASK-Manager.
Especially in bigger drawings.
Just short before the RAM limit (only 5% free) there seems to be a limiting behaviour in BC.
Also SAVE will slow down (with every REGEN ... more and more).
This could result in crashes … maybe a BUG ?
Can you confirm this?
Thanks for attention …
Peter
I tried to replicate your issue but my memory never went above above 4GB and sometimes even when lower. Could you give us the following info.
OS:
BricsCAD Version:
File Size:0 -
I will ... if this fact is through support.
I'm still waiting on respose.0
