Help! - papaer space / layout flipped 90 degrees
akendall1966
edited April 2017 in 2D Drafting
OK it was all going so well.......
layout1 seems to have flipped onto a different axis. The a little symbol bottom right of the view port that was showing an icon for a sheet of paper with a w on it and a couple of line. Now I have got a horizontal L with a X at the end.
No idea how I have done this or how to get back to an orientation I can continue with. but I still see the drawing as it was but if I try and add a dimension its like I am looking at the edge of the page.
  • If you type UCSW, it should come good - the UCS had been changed.
  • That didn't turn out as I typed it, try "UCS" return "W" return
  • UCS and Enter (Return) twice does restore the World UCS.
  • Thanks Gents,
    WCS restored can continue to work of the layout know. You prompt advice is greatly appreciated.
    AK
