OpenDCL support for BricsCAD Classic
Hi
Can it be that OpenDCL is not supported in Classic mode?
I want to load / use the "Color_swatch" tool but get this error message..
- Unable to recognize command "OPENDCL". Please try again.
\AutoCAD\RST2015 lokaal\Bricscad\BricsCAD_color_swatch.lsp successfully loaded.
- csw
; ----- LISP : Call Stack -----
; [0]...C:CSW <<--
; ----- Error around expression -----
(DCL-LOADPROJECT "color_swatch")
; error : no function definition <DCL-LOADPROJECT> ;
Dear Hans,
yes, you will need BricsCAD Pro or higher ... that is, because "Classic" can run Lisp, but not BRX modules as OpenDCL.
hope this explains a bit ?
many greetings !0 -
thanks for your fast respons
I was afraid that might be the case. ;-)0
