VBA Enabler for BricsCAD Pro 16
I have been programming plenty of VBA / LISP routines for AutoCAD. Yet I'm new to programming in BricsCAD.
We are currently using BricsCAD version Version 16.2.15 (x64)
This 64bit version doesn't seem to support VBA as I get Commandline error:
"VBA is not available in the 64 bit version."
Is there a seperate VBA-Enabler?
Dear Martijn,
with V16, VBA is only available with x86 / 32 bit BricsCAd version.
But with BricsCAD V17 we switched to new VBA 7.1, available for both x86 and x64 BricsCAd versions
(you only need to install the VBA runtimes, from ./VBA sub-folder of BricsCAD V17 installation).hope this helps a bit ?
many greetings !0
