Settings to make vertical zero degrees
Hey guys,
How do I set up so that I have zero degrees vertical and angles are measured clock wise?
There are settings here under Options
Settings/Drawing/Drafting/Drawing Units/Angular Unit
Do I set the base angle to 270 or something like that?
Silly question I know but I'm having a moment...
Cheers,
L.
ANGBASE should be 90. To check this value just look at the image in the bottom right corner of the _Settings dialog.
Beauty thanks Roy!
