Creating Viewports with different Visual Styles via the BIM Section commands
When I create a BIM Section (Elevation type), and go on to place it in a Viewport on a Sheet via the BIM Section set of commands, I can't seem to set the Viewport to a different Visual Style, and by default a Visual Style similar to Hidden Line is created.
Is it possible to change the Visual Style of a Viewport created through the BIM Section commands, for instance to Modelling or Realistic?
I'm using V16, but intend to upgrade to V17 soon.
Thanks in advance for any help!
Hi Graeme,
BIM Section generates a 2D view from the model, because of this changing the visual style of the viewport won't really achieve anything.
In V17 you can use a command called PLACEVIEW to place views of your model. This is most easily done using the content browser.
To use you save a VIEW (or create a CAMERA) in the Model, then in your target drawing you would use PLACEVIEW to bring this view in. Essentially it creates a clipped xref, but this allows you to apply different visual styles if you want.
CAD Concepts0 -
Many thanks Jason
I'll give that a go!
Graeme
