BIM Section XREF
Hi I'm testing out BRICScad and I'm very interested in multistory models. The goal is to xref multiple floors. When I xref a prototype floor and create a BIM section only one of the xrefs look correct. Is this a limitation of xrefs?
Maybe this tutorial will help you (I am also new with BricsCAD BIM ;-))
Please notice that, compared to what you see in the movie, the creation of sections has been improved dramatically in V17. See the BricsCAD Help under User Guide / BIM / Defining BIM Sections / To Define a Plan Section - Cross Section - Elevation - Detail Section. BIM sections are now created with two mouse clicks and the Clip Display property of a section is automatically switched on during an after the creation. Double click a section entity to toggle the Clip Display property. Multiple sections can have Clip Display on simultaneously.
Thanks for mentioning Louis
