SelectSimilar still applies globally after using Isolate
I have transitioned to BricsCAD (V15) from AutoCAD LT. For my work, I often need to change properties of similar entities, which I used to achieve efficiently in AutoCAD LT by isolating the area with the objects I needed to work with, using SelectSimilar, and then performing the desired tasks. What I find in BricsCAD is that the tasks affect ALL similar objects in the drawing, and not just the ones I have isolated. I have a workaround where I copy the entities into an empty drawing, and perform the tasks there, then copy back - this works, but I would still like to solve this if possible.
From what I've gathered, this is due to the behaviour of the IsolateObjects command.
Is there a system variable or other option that I can change to alter this behaviour? Does anyone have similar experiences?
Would appreciate any help. Thanks!
Apparently there is an incompatibility here (and you should submit a support request).
Possible workaround:
Instead of isolating object do the following:- Use _SelectSimilar to select the objects.
- Enter '-' or '_R' or '_Remove'.
- Enter '_O' or '_Outside'.
- Select a window.
- Result: all object outside the window have been deselected.
Thanks, will do.
I'll try the work around, but as I usually need to repeat the command several times, it may still be more efficient to copy into an empty drawing.
Thanks again!
Based on your bug report I have modified my BKG_SelectSimilar routine. I have added the 'Visible' filter option. BKG_SelectSimilar is not exactly the same as the built-in _SelectSimilar command, but you may find it useful.
Howdy, Stranger!
