Form Component
Hi All,
I'm a new user of Bricscad and want to use the Form Component with a specific template file .dwt so I can create a layout drawing with my dims styles layers etc within the file and not the assembly. Does anyone know if this can be done?
Cheers
Miles
Or is there a way to select a nested part within an assembly using the View Base command. I can only choose the top level file ?
