vba and changing field values
can anyone help me with this? I am trying to change the value of fields with vba. I have a program that draws a full drawing from excel but I cant get the field values to change in the process.
keep solving my own issues.
here is how you change the values of your fields (via vba) under drawing properties
Dim Value As String Dim Num As Long Dim Index As Long Dim CustomKey As String Dim CustomValue As String Dim Sum As AcadSummaryInfo Set Sum = ThisDrawing.SummaryInfo Num = Sum.NumCustomInfo For Index = 0 To Num - 1 Sum.GetCustomByIndex Index, CustomKey, CustomValue If CustomKey = fillArray(Index) Then Sum.SetCustomByIndex Index, CustomKey, "Test" End If Next Index Set Sum = Nothing
I found the necessary code here:forums.augi.com/showthread.php?94942-Drawing-Properties
I altered it to fit my needs. It is my intention to use this information to populate my fields with values from an excel sheet.
Your use of the word 'field' is confusing. Without the additional info of your 2nd post most BricsCAD users (and programmers) would probably think of this first:
https://www.bricsys.com/bricscad/help/en_INTL/CurVer/UsrGui/source/10_Drawing_Entities/05_Working_with_Text/10_05_08_Working_with_Fields.htm#Commands0 -
Roy,
those are the droids fields I'm looking for. For example our title block (like most peoples title blocks) use custom fields (drawing properties) across all layouts to make sure all the title data matches. These are the fields I could not find information about changing via VBA (until yesterday). As most cad users i searched "how to update fields with vba" when i should have been searching "summaryinfo"does this make more sense?
nvm
