Corner reliefs and flanges not equal.
I just tried today to make a basic column using the Sheet Metal tools and I get some ugly results. Seems that the flanges are not equal and the corner reliefs are bigger in one side than into the other of the same corner. Also I need only 1mm between the flanges and I can't find any option to decrease the size between flanges. How to properly made a sheet metal part like this starting from a box? I attached my .dwg experiment for better understanding.
How I can bend and create a new flange in one side at "junction_5"? I need some extra material that will go under the other side for soldering.
Hello Dacicusan,
The best way to model such column is "from solid". Check the video for more information https://youtu.be/ytyv2k8cwAg
Don't hesitate to ask questions if you have some0
