mechanical workspace black background?
white background color cant see object created specially sketch
If normally do 2D stuff in black and 3D stuff using a white background.
Lisps for2D => switch to 2D env.
3D => switch to 3D env.However, i need to get [GRAPHICSWINLAYOUTBACKGRNDCOLOR] fixed because BricsCAD does it diffent.
My $
I use this:
(defun c:BB ()
(if (equal (getvar "TILEMODE") 0) ; if tilemode is Off, then we're in a layout tab (which can have non-tiled viewports)
(if (equal (getvar "BKGCOLORPS") 7) (setvar "BKGCOLORPS" 256) (setvar "BKGCOLORPS" 7))
(if (equal (getvar "BKGCOLOR") 7) (setvar "BKGCOLOR" 256) (setvar "BKGCOLOR" 7))
)0 -
I see that the code I posted only works in 2D.
Ans Background dialog is the only way to change it.0
