How to make BMEXTERNALIZE use template
I have imported a .step file assembly with various compenents. When I use the BMEXTERNALIZE it creates the new files the same way as "Start from scratch" when using the "New Wizard".
I would prefer it to use my customized default template instead?
Same story when using the "BMOPENCOPY" command.
Any help is appreciated.
