HatchPatterns
Couldn't you use a .GetFiles (with subdirectories) on each split (";") of the search path to collect all .PAT files and parse them for pattern names? That way you would even pick up user added patterns.
Hi Terry,
.GetFiles is just a windows search in the support directory?
Thanks,
Petra0 -
Directory.GetFiles is the .NET Directory function, pass it each of the paths in the support path after splitting on ";"
Application.GetSystemVariable("ACADPREFIX")
Remember that each .PAT file can contain multiple pattern names starting with an asterisk like "*GRAVEL".
Thanks a lot!
