Import dwg or dxf file as block by "drag & drop"
Hi guys, the function "drag & drop" doesn't work well as in autocad. I mean when I drag and drop a dwg file into a bricscad, it open the file in new tab but I need to insert it as a block. Can anyone show me the right way ? Many thanks in advanced.
Howdy, Stranger!
