scaling to known reference
What are the steps to scaling an object from its current size to a known reference?
Hello,
the Option B in the command is the key...
Copy/Base scale/
Regards
Another option is to use the ALIGN command, where after specifying the points you have to option do scale the objects.
Thanks for the comments.
It appears I was "doing the right things"
But in the wrong sequence.All good now
-T
