copypaste
Hello.
"_copyclip" - "_pasteorig" does not work in the same drawing.
Not even from layout to layout...
Anybody know, why?
How to enable?
Thanks,
Sascha
maybee its not build for this. _pasteorig only works in different than the base drawing, where the items were copied.
What's the idea behind your behaviour?0 -
The normal PASTECLIP command pastes to the original coordinates specified in the COPYCLIP or COPYBASE command if you press Enter instead of picking or specifying coordinates to paste to. That works within the same file that the selection set was copied from.
