typing commands does not work
Hello,
1.After some days of working in brickscad we suddenly can't type commands but only work with icons. What is the way to get it back?
2. Our brickscad works very slowly with external referances (it gets stuck). Is there a way to solve it?
Thank you!
- Shift + F2
Concerning the slow performance with xrefs: if you file a support request and attach a drawing set with which you experience this slowness, our analysts will be glad to investigate the issue and help you out.
We see a similar problem with typing commands. After working in a drawing for an extended period the characters we type are still echoed to the command line but will be out of order, with the new characters typically appearing at random in the middle of whatever text was already in the command line. Nothing we have tried allows us to clear the command line. We have found that we need to reboot the computer when this happens. If we simply close then reopen Bricscad without a reboot then Bricscad will not be stable.
