Copy (Ctrl + C) Error
Hello,
i have a problem with the CTRL+C (Copy) Command, or copyclip.
if i am in an BKS i get an error if i try to copy something
If i am in the WKS i have no Problem to copy elements.
The error occurs not every time; sometimes i can copy also in the BKS for a while and then the error starts to happen and won't go away.
did anybody had the same Situation, and maybe knows how to fix this?
Thanks
Please file a support request and add a drawing you are having this issue with. Our analysts will be glad to find out why it goes wrong.
I'll do that, thank you
