Diameter symbol
When I try to write de %%c for the diameter symbol appears an ? or a square symbol depending on the used style (ttf or shx). How can I correct it?Thanks
I had this problem with ROMANS, ROMANC, and the few other fonts I use. Try copying Autocads font files (if you have access to them) to your icad font directory and use them instead of those provided by icad. It worked for me.Jef
