Imac Pro and Bricscad
I was wondering how the Imac pro coming out later this year will work with Bricscad? Will it be compatible?
  • My Bricscad Demos ran fine so far on my nMac Pro
    with Xeon, ECC RAM and ATI GPUs.
    Why should the iMac Pro be any problematic ?
    Not sure how many operations in Bricscad can run multithreaded.
    So in the end you may be faster with a cheaper consumer CPU that
    has a higher single core or turbo frequency.
    iMac Pros fast GPU with lots of VRAM will help displaying more complex
    models on screen by OpenGL.
    thanks!
