Printing to PDF in V17.2.09-1 for MAC
I recently updated BricsCAD from V17.2.05-1 US to V17.2.09-1 US (for MAC) and find my PDF exports either lose their arrow heads on the dimensions or the dimension numbers become very large. File attached. The drawings are simple 2 D drawings. Exporting the same drawing to pdf in V16.2.17-2 (I have both versions installed) works correctly. Changing the settings seems to have no effect.
Is there a workaround or an update in the works that will correct it.
+1
I'm expiriencing exactly the same problem on MacOS 10.12.6 ...0 -
Are you still using V17.2.09?
If so, please update to V17.2.13, it includes an important fix for font sizes in PDF exports.0 -
Hi Tijs,
thank you for your reply. Yes, I'm still stuck with .09, as there is no Czech localization avalaible at this moment and I'm testing for further deployment to end-users who unfortunately need localized application. I will wait for the .13 version and test it as it will become availaible for download. Good news is that this regression was taken care of in a quick way and the patched version is on the way. Thanks.0
