[SOLVED] Autozoom and auto cotation : lines flickering
Hi
Maybe my computer is not powerful enough, but I would like to disable auto-zooming and auto-cote when I draw.
I could not find easily an anwser, so any further guidance is much appreciated.
If I cannot disable that, it is almost impossaible to draw : the screen always flickers, and zoom factor is always changing when I get near to an anchor point
Thant you for your answer.
Christophe
PS : setup is linux 4.10 with Ubuntu 16.04 up-to-date. Brics Version 17.2.11 (x64) revision 49654
I think your issue is related to two variables: UCSDETECT and UCSFOLLOW. Try switching UCSFOLLOW off.
Hi Roy,
Sorry, this had no effect.
I found the solution, but I forgot to write it down.
And now I am still looking for it.
I remember, it had to do with setting a parameter from 1 (or 2, or 3) to 0...0 -
here is it for everyone :
set GLSWAPMODE to 0
"New current value for GLSWAPMODE (0 to 4) <2> 0"NB : it has been the case for all my bricscad versions under linux
