How does eTransmit supposed to work in BricsCAD?
I can get it to work for a single drawing file, but can't seem to add multiple drawings into a zip file.
  • Hi Bernal,
    You can't currently select multiple files to etransmit. A workaround is to create a temporary SHEETSET of the files you want to transmit, then run the etransmit option from the Sheetset panel.
    CAD Concepts
