Pdf and Dwf export margin problem
Hello,
if I try to export to a pdf file my drawing, it is automatically resize e reduce to the paper size format. I tried to modify the pdf export option like the attached picture. I've the same result if I export to a dwf file. There is a way to modify the margin fo the export file?
Thank you very much
