zoomed-in accuracy of points
Having had trouble getting snaps to hit the desired spot (now I think solved), I did much zooming-in to see just where an entity had actually been placed, relative to the intersection of guidelines (not GRID) where it was supposed to be.
When zoomed-in, the corner of the entity seems to jump all around the guidelines intersection. Turning off Snap, Grid, Ortho, Polar, Esnap, Strack, and visually clicking to take DISTANCE between the two, I get as much as 0.1mm apparent discrepancy, although Properties indicates it's actually spot-on.
Is that OK? 0.1mm seems a very coarse apparent discrepancy, if it's just a visual artifact. I could well be zoomed in to draw things smaller than that, but the graphics apparently cant't cope? It makes it impossible to visually check the accuracy of placements. Is there some setting?
I have the latest K2100M driver that's certified on the HP site, in my Zbook15.
