Copying to clipboard, copying 3d objects to another .dwg's model space. How?
bricktop
edited September 2017 in 3D Modeling
I am trying to copy something from drawing to drawing.
Every time I pick entities, pick base point and i can copy objects within one drawing, but when I move to the 2nd one, it tells me that clipboard is empty.
  • See the BricsCAD Help under User Guide / Modifying Entities / Copying Entities / Copying Entities Between Drawings to learn the various methods to copy entities between drawings. If these procedures fail in a drawing of yours, please file a support request and add the drawing you are having issues with. Describe in detail which entities you want to copy/paste in order to reproduce the problem.
