Windows 10 update and Bricscad 15 hangs on startup
I'm assuming a recent Win 10 Pro update caused issues to Bricscad and my survey software.
BricsCad is my default dwg program.
Open Bricscad and let it open last dwgs and it rattles through the process smoothly.
Double click on a dwg file and it immediately fires up Bricscad but then hangs.
The command prompt last entry is referring to fonts substituted.
I've never got it to open that way since issue started.
Once open from first starting Bricscad there doesn't appear to be any issues at all in application.
Not being confident to reset anything without losing other settings I ask for any advice please.
If it means a complete reset to default then so be it.
Comments much appreciated thanks.
Howdy, Stranger!
