cursor window
Hello, I want to make dissapear the window that appears when you put the cursor over an element. Thanks
Hi - most likely what you are referring to is the Quad Cursor (QUAD) and Rollover Tips (RT). You can toggle these on and off in the Status Bar (bottom right). You can also access the Quad Cursor Setting by right clicking on QUAD. You might also want to switch off the TIPS (black window coming up)0
