Raster image reference
Hi, how can I update the raster image reference path in brics 2017?
I use two pc on different locations and the path gets broken... how to update like autocad?
Thanks
It is usually better to use relative paths instead of absolute paths.
To switch to relative paths this tool can be used:
http://www.b-k-g.nl/bkg_makepathsrelative.html0 -
@Roy Klein Gebbinck said:
It is usually better to use relative paths instead of absolute paths.To switch to relative paths this tool can be used:
http://www.b-k-g.nl/bkg_makepathsrelative.htmlHi Roy Klein Gebbinck,
thanks for your reply and help. Did all in the instructions but for some reason that might be my own fault, I can't make this work.
bkg loads and asks for the file type xref/pdf/jpg/ etc. If I click jpeg it display console message: I
Nothing else happens.
Thanks.
Samuel0 -
The program does not prompt for a file type.
The prompt is:Make paths relative for: Xrefs/Pdfs/Images/Hyperlinks/All:
Clicking on the PROMPTMENU should work. I don't know why it fails in your case. Try entering 'Images' on your keyboard instead.
