Command ANNOALLVISIBLE
Hello everyone!
I have BC V17.
Does the ANNOALLVISIBLE command work? I'm trying to turn it on and off but there are no changes to the drawing. All scales are displayed after the object is clicked, not just one defined by the CANNOSCALE command.
You have misunderstood the ANNOALLVISIBLE variable. Please check the short, but clear, explanation in the _Settings dialog. SELECTIONANNODISPLAY is probably the variable you are looking for.
@Roy Klein Gebbinck said:
You have misunderstood the ANNOALLVISIBLE variable. Please check the short, but clear, explanation in the _Settings dialog. SELECTIONANNODISPLAY is probably the variable you are looking for.Thank you very much!
It's works0
