Alignment Parameter for Dynamic Blocks
Should the alignment parameter in dynamic blocks be working? If not, is there a way in lisp to mimic the behavior?
Not exactly but getting closer ...
(setq nStation (getreal "\nStation: ")) (setq pInsert (vlax-curve-getPointAtDist en (- nStation nStartStation))) (setq nRot (angle '(0. 0. 0.) (vlax-curve-getFirstDeriv en (vlax-curve-getParamAtPoint en pInsert)))) (setq nRot (+ nRot (/ pi 2))) (setq myBlock (vla-insertblock mspace pINsert "Station Label Rt.dwg" *nHScale* *nHScale* *nHScale* nRot))
