Viewport within viewport
You can make viewports on top of one another, but not really inside one another. Maybe you need wipeouts or background masks in between. But it's usually not a good idea if you can avoid it because odd things always seem to happen with draworder and the results are often not as intended.
Hi Barrie,
you can make a region as viewport, containing the wished gap.
Aftertahat you can insert the second viewport inside of the gap of the region.Regards
Mustafa
Howdy, Stranger!
