Crosshairs and Toolbars
in 2D Drafting
Crossed over to Bricscad a while ago from AutoCAD but have 2 queries:
Can the Z axis on the crosshairs be turned off as in AutoCAD when viewing in 3D?
Can floating Toolbars be dragged to form a grid of icons, as in AutoCAD, and not just the straight row?
Thanks in advance.
Regarding the toolbars, I do not see any way to alter the shape of a toolbar, as you describe.
In AutoCAD, you can do this by dragging the corner, or inside the -Toolbar command, but neither work in BricsCAD v17. -
To change the shape of toolbars you have to change their 'rows' attribute in the .cui file.
<Toolbar ToolbarOrient="floating" ToolbarVisible="hide" rows="1" UID="ID_TbRefEdit">
Howdy, Stranger!
