Linetype scale different lines
sander
edited October 2017 in 2D Drafting
Hello,
In the template i have set the global linetype scale to 200.
The result is that the "hidden2" lines are correctly displayed but the center lines are not (should be approx 50 times smaller).
Is it possible to set the linetype scale per linetype ?
i have also checked the ISO.lin file but i can not see anything extraordinary in there
*CENTER,Center ____ _ ____ _ ____ _ ____ _ ____ _ ____
A, 31.750, -6.350, 6.350, -6.350
*HIDDEN2,Hidden (0.5x) _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
A, 3.175, -1.5875
Sander
  • Check if the MEASUREMENT setting in the template is correct and reload both linetypes.
    You cannot set a linetype scale per linetype. But creating your own linetypes is not very hard.
  • Or change the linetype scale for the particular objects
