Dim
in Other
Hello I am having some trouble with one command. I am not sure of the word in english i think its the command dim. When i change the configuration of the text in this command the size remains the same, it didnt happen until now, it doesnt happen in other files only in this drawing i am doing. Thanks
If you file a support request and add the drawing you are having this issue with our analysts will be glad to help you out. Explain in detail what you want to achieve.
To translate commands:
http://www.cadforum.cz/cadforum_en/command.asp0
