Reporting viewport scales and setting viewport scale (USCL command)
The REPORTVIEWPORTSCALE AND USCL command don't seem to be working in V17. Is there another command or a lisp that can do the same.
Thanks,
Akash
  • Akash, I don't know what you mean by REPORTVIEWPORTSCALE AND USCL command, and I can't find any reference to either of them in Autocad or Bricscad; but if you are looking for a way to know the scale of a viewport, just select it and read the Standard scale field of the Properties panel.
