Fullscreen
Hi there fellows, is there a way to make brics go fullscreen with only command prompt appearing?
Thanks
Best regards,
Samuel
In the upcoming V18 release the CleanScreen command is introduced. This command allows to toggle the various components of the user interface on/off. In older versions you need to create a user profile in which the user interface items you do not want to see are switched off.
That's great! Thank you for your answer.
Howdy, Stranger!
