v17.2.13-1 freezing while trying to move block inserted from external file
in Mac
in v17.2.13-1 BricsCAD freezes everytime we try to move around a block which was imported or copy/pasted from external file.
You can insert it and select the block, but if you try to drag it to another position the program feezes in 100% reproducible way (while starting the move action).
So the workflow now looks like:
- open and edit / draw in V16
- if you want to publish to PDF and send to customer close V16 open the finished drawing in V17 and print to PDF (which works fine now in v17.2.13-1).
Anyone else who can reproduce and confirm this?
Or do we have to set some flags to different values???
Thanks in advance.
