Using DIMBREAK on MLEADER
Usually crashes at the point of using dimbreak on mleader.
Anyone else with the same issue?
Could you please file a support request and attach a sample drawing and a short description how such crash can be reproduced?
Our team will be glad to investigate and apply fixes where needed to solve this issue.0 -
I will attach a file that uses the mleader style "MY1" and "MY2" .
The problem seems to revolve around the mleader style.
Try using dimbreak and then moving or copying the objects, as i am not able to save the file after using dimbreak and moving them around0 -
the update till now
Saori Takai
29-03-2018 06:28 UTCsorry for the late reply.
I confirmed the problem,when Landing settings is checked off.
V18 also includes similar problems.
We will report it to our development.Best regards,
"0
