Cannot add constraint for mid-point of rectangle polyline shape
Hi, I am switching from Fusion 360 to BricsCAD.
I draw a rectangle, add horizontal and vertical constraints.
Than I add a line, I can add a coincident constraint at the end point of the line and the corner of rectangle.
I want the other line end constraint to the middle of top side of the rectangle, I use coincident and snap to mid-point, when I set the line endpoint to the mid-point of the top line of rectangle, failed with error "Could not create geometric constraint: Error adding constraint".
Enclosed is the screenshot, I want one of the line endpoint coincident to the top line of rectangle.
Sorry for my poor English.
I found if I explode the rectangle, I can constraint to the mid-point of the top line.
But I have another problem, I don't know how to add a coincident constraint so that the black line coincident to the top line of the rectangle.
- Start the _GcCoincident command.
- Pick the endpoint of the vertical line.
- Press Enter to select the Entity option.
- Select the top of the rectangular shape.
@Roy Klein Gebbinck said:
1. Start the _GcCoincident command.
2. Pick the endpoint of the vertical line.
3. Press Enter to select the Entity option.
4. Select the top of the rectangular shape.Ah I missed step 3. It works now. Thank you very much!
@fredericklim:
BTW: The issue you mention in your original post is really a bug. In some cases BricsCAD is able to add the _GcCoincident constraint. It all depends on the order in which the constraints are added. You should send in a Support Request.Adding the _GcCoincident constraint first and then the _GcHorizontal constraint will work. There is also no issue if the _GcHorizontal constraint was added right before the _GcCoincident constraint.
Yes I also think that would be a bug, If I add coincident constrain to the mid-point of right vertical line is OK, but the top horizontal line is not.
I will submit a support request.
Thank you.
Adding the _GcCoincident constraint first and then the _GcHorizontal constraint will work. There is also no issue if the _GcHorizontal constraint was added right before the _GcCoincident constraint.I tried your constraint sequence and works.
The following sequences for assign a mid-point coincident constraint are failed:
Add a horizontal constrain on the top line, then a vertical constraint on the left or right vertical line.
Add horizontal constrain on the top line and the bottom lineBut works if
Add a vertical constrain on left and right lines, add horizontal constrain on the bottom line, I can add mid-point constraint to the top line, very strange.What constraint engine BricsCAD based on? D-Cubed dcm or in-house engine?
I see. I wonder the mid-point coincident bug is in BricsCAD or LGS 2D. My bug report is not respond yet, the inconsistent behavior of constraint is not very usable to me.
I bought BricsCAD Platinum mainly because it has 3D constraint, but the 2D constraint is not even stable. Hopefully that will be fix in v18.
FYI: 2D and 3D constraints should not be mixed.
