How to start drawingexplorer at ucs from lisp
when i type expucs from the commanline, the drwaingexplorer starts in the ucs-section. When i use (command "expucs") from lisp it starts the ucs command.
How can i start the explorer as desired ?
Mathias
I just found out, that the problem is a little bigger...
Type expucs, hit new (._ucs is started) say origin, select the new origin - after that you are flipped back to drawingexplorer and you can rename the newly created ucs.
But when i use (command "._ucs") from lisp, do some things in lisp and start drawingexplorer using (command "_explorer") there ist no new ucs to be renamed.
How can i automate the manual way ?
Mathias0 -
To save the current UCS choose the _NAmed option of the _UCS command. Note that you can also 'entmake' a UCS or create one using 'Visual Lisp' code.
Code example:
(if (not (tblobjname "ucs" "MyName")) (command "_.ucs" "_world" "_.ucs" "_z" 45 "_.ucs" "_named" "_save" "MyName" "_.ucs" "_previous" "_.ucs" "_previous" "_.ucs" "_previous" ) )0 -
How can i start the explorer as desired ?Just to answer this initial query, In LISP you can use INITDIA to force the display of the dialogue version of a command e:g
(initdia) (command "._EXPUCS")
CAD Concepts0 -
A combination of both did the trick.
Thank you Jason and Roy
Mathias0
